F250 springs in a bronco or F150
its about 3-4" if they are 4x4 f250 springs
2wd 250 springs are only 2 1/2" wide, the bronco springs are 3" wide
I'm looking at doing it right now. Its about 5" if you put the sterling from the f250 under the bronco (the axle tubes alone lift it 1/2"-3/4").
you get another 1" if you put the f250 frame under the bronco. I know people say the bronco/150/250 frames are the same height but the 250 frame rails are about 1" taller (at least the late 80's HD frames)
it you want cheap 3" lift coils for the front put in coils from a 90s E350 2wd DRW diesel van.
The 2wd 3/4-1 ton springs are great (along with a set of helper leaves in the back) to use if you plan on towing anything as like said above they are a stiffer spring so as to handle the higher loads, great for heavy work but you end up with a harsh ride afterwards though, good cheap way to level the front.
If you do do a front leveling (2" about) spring of sorts you need to get a set of new cam bushings made for the top ball joint (you can buy them too) on the knuckles so the camber can be put back to where it needs to be (2" is about the safe max for a lift and cam bushing, but you can get away with about 2.5" with the bushings, if you don't mind a bit of tire wear.) I know this from when i had to do the alignment on my 82 flareside when i dropped it.
f100beatertruck
30
06-20-2022 08:13 AM
ostrx250
04-14-2011 10:08 PM
TheMechanicalAnimal
02-10-2010 11:41 PM
