Smoke from oil fill tube
i just bought an 82 f-100 with a 302 also...and there was smoke coming from the oil fill tube also...try doing a compression test, you could be getting excessive blowby. i did a compression test on mine and only had 2lbs on #7 cylinder. So im guessin thats my problem. I should have the heads off this week to have a look.
Another thought....
When I did the swap, I used the valve covers form the Truck. THe valve covers on the donor engine had the fill tube on the passengers side, and PCV on drivers side. THe valve covers I used were the opposite. Should that matter?? New pcv valve, but I will check and make sure it is not clogged. I hope it is not a bad cylinder.
arwford
08-23-2010 06:39 AM
78xltcrewcab
02-21-2007 04:45 PM
Nathane
04-10-2006 06:55 PM
