Darned cats!
i think thats what it is dude. mine only does it at idle, when the engine goes it either gets covered up by the engine/exhuast noise, or just doesnt rattle.
It gets a little worse, every day. Started sometime shortly after i put on my flowmaster. One day, i'll hack them and throw in some hi-flows.
Originally Posted by travlnman
Yep, I still have the pieces, I saved them for proof that I was not crazy. My driver's side broke up, the first one, and rattled like crazy. I think Motorhaven has some that are the cheapest I've seen so far. Remember, one high flow replaces two stock cats.
But when i do it, i'll only use 2.
also, try eBay, for CATCO cats. usually a little over half the price of magnaflows
Originally Posted by true4.2
Yup, I'm getting used to it myself, but I guess some el-cheapo high flows would be good to have. They wouldn't really give me anything performancewise, but the sound gone alone would be worth it.
and it'll get a buttload louder
Cats can be warranty
I had the same issue with my 1999 F-150 with the rattling broken cats. I had Ford replace both sides twice! Finally I am out of warrany now and my drivers is doing it again. I have gone to www.cheapexhaust.com and found them both for a total of $500! I have though that of switching it but I run straight 3" exhaust from the cats back (no muffler) so that would be really loud. Without the muffler it sounds great but I do have neighbors to think about.
For BUSA01- You only have 15K on your truck! When it is making the noise pull into a Ford dealer and let them hear it. I work at a dealership as a service advisor and if you can display the issue they cannot ignore it. Get it covers for free as long as you can!
Flowmasters
Having flowmasters from the Cats back has NO EFFECT on your warranty! I work at a BMW Dealer and I cannot void a warranty unless you have disconnected your O2 sensors or modified the manifolds in some odd way. There is a FEDERAL LAW stating all emission contol items (catalytic converters) are covered by manufacture warranty for 8 years/80000 miles. I just replace two cats on a 1998 740il with 78500 miles and they weren't as loud as the ones on my truck.
So, if all you have done is put mufflers on you have done nothing to void your warranty. I had my second set installed with a cat back Roush Racing system on mine.
Good luck
Smokey
Good luck
Smokey
