Special tool to remove a headlight?
I've run into one of Ford's 'better ideas' while replaicing all my '95 F150's front lamps with diamond-cut units. Apparently, in all Dearborn's wisdom, we are protected from headamps that spontaneously eject from the vehicle by the invention of a Edited for content by FTE clip that holds the adjusters to the steel panel behind them. I'm told I need a unique tool (that nobody local seems to sell) to pull these E-clip-type things up and off so that the headlamp will come out. Hmm....after dealing with headlamps falling out of my prior vehicles a total of ZILCH times, Ford found a cure for a non-existent disease! Kudos!! Now my truck sits, lights tossed aside, bulbs hanging, trim...somewhere I don't recall anymore....while I sit here, venting at you folks. In the 90-degree heat, it was best I stop, cuz I was looking at the crowbar a little too long.
I tried to side-step this moronic procedure by turning the adjusting screws out all the way, but NATURALLY, the top/inner on the driver's side is seized and stripped.
Sooooo.......any ACTUAL 'better ideas' out there???
Originally Posted by 93f250pos
how did you get the lights out?
We are pleased you have chosen the best source for Fords!
See you on the boards.
Enjoy FTE …..
huronfarmer
02-06-2005 08:04 PM
