Factory fiberglass running boards,92 Flareside
I have a 92 F150 Flareside with the factory fiberglass running boards. The mounting hardware for the running boards is in poor condition and I'd like to replace it. There is a metal tube that runs underneath the boards and holds them in place. On my pickup these tubes are rusty, and I'd like to replace them ASAP. Does anybody know where I can get replacements for this mounting hardware?
I would try the bone yard. Take a look at :www.car-parts.com. That site will list many salvage yards in your area.
I assume that you are referring to factory running boards and not the aftermarket style .
on
I got my factory set from ebay for $100. They were from Wisconsin and I am having a from copy the mounting hardware in stainless so it wont rust anymore and last longer. I would suggest taking the hardware to a metal shop and see what they can do to fab a replacement set in stronger steel or stainless since it is just tubing mostly.
I have a 1992 Flareside w/a 5.8l(351) one of the most dependable trucks I have ever own. It has 150,000 miles and always starts. The problem I have now is the factory running boards support on the passenger side is rusting away. 2 years ago I replaced the driver side,it cost under $200.00,now they want over $400.00 . What a rip. I will probable replace it with a aftermarket running board,and I am sure it won't look as nice as OEM. Just venting.
Originally Posted by Ponyracer
Why not take the support to a metal shop that can do tubing and have them make you a set out of thicker and higher quality steel tubing? I am going to have a friend of mine duplicate the supports in stainless tubing for mine.
Originally Posted by JohnT
Is that $400 for the running board and mounting support, or $400 for just the mounting support? I need to replace the support on the passenger side of my 92 Flareside, too. If it's going to cost 400 for the OEM part, I guess I better start saving right now! I'm going to wait until spring anyways, because right now the truck is parked for the winter.
on
how much does that cost? would your friend make two sets?
GOOD LORD!!! I know what part I'm going to start making and selling on e-bay! Steel supports for these running boards is TOO EASY to make! Basically, anything would have been stronger than the factory junk. I'll make a set for mine (when and if I can locate a set) and will let you guys see some pics if you're ever interested later. The one thing I'll guarantee is they won't cost more than $20 a set!
