ZF 5-spd gear ratios
For comparison, the NP435 ratios are: 6.69, 3.34, 1.79, 1.00, rev- 8.26. There was also a close-ratio NP435, but I don't think it was used in Ford trucks.
If you don't like the one-piece aluminum case and hydraulic clutch of the ZF, but still want a tranny with a granny and an overdrive, you may want to look into the NV4500, which is an iron-cased granny tranny with a seperate bellhousing and top-shifter like the NP435, but with an overdrive tailsection .
NV4500 ratios for the Dodge version are: 5.61, 3.04, 1.67, 1.00, 0.74, rev- 5.61 or 5.04. This was used in Dodge and GM trucks in the '90's. The early GM version has wider ratios (6.34 first), but isn't as easily adapted to other engines, from what I hear.
This is a good chart. It has all the popular manual tranmission gear ratios.
http://www.fordsix.com/trucktranny.htm
Originally Posted by aurgathor
5.72 2.94 1.81 0.76 | 5.24 or
4.14 2.37 1.42 0.77 | 3.79 in '95.
also, what's the difference between a T-18 and a NP435??? I've got a T-18 in my 1/2 ton 4x4, and love it, but i'm looking at a F-250 4x4 with the NP435??? is the NP got a synchro'd 1st? what're the gear ratios for the two of them??? curious...thanks
MontanaFord
Montana Ford, both the NP435 and the T18 are only synchro'd on 2nd through 4th gears. No synchro on 1st or reverse. Both are iron case heavy duty trans with PTO provision. The T18 is one inch longer than the NP435 and the ones used in Fords are interchangeable as far as mounting bolt patterns and input/output shafts. The trans you're thinking of with full-synchro gears is the T19, which is very similar to the T18.
The T18A ratios are: 6.32, 3.09, 1.69, 1.00, rev- 7.44.
The close ratio T18 and T19 ratios are: 4.02, 2.41, 1.41, 1.00, rev- 4.73.
The T18B ratios are: 4.32, 2.26, 1.51, 1.00, rev- ?
Another T19 ratio set is: 5.11, 3.03, 1.79, 1.00, rev- ?
Rustyol79
04-09-2017 07:37 AM
74crwcb429hibPS4spd
01-07-2003 01:28 PM
