Altenator Options On A 292
I have a one wire GM alternator on mine also. However, a two wire GM alternator is very easy also. I put one of them on my 54 Ford tractor. It was out of an '86 S-10. It would work on a 292 just as well. On any alternator you will have to figure out your own mounting or buy somehing. Not sure who sells the conversion hardware.
I had to modify the generator mounting bracket to accomodate the 1 wire alternator. The modification is similar to the one shown on http://www.ranchwagon.com/tech/alt/alt.htm
Originally Posted by JByrd1173
What Can I Use On My 292 For A Altenator
I don't know if it will be of any help, but if you look in my gallery... I have a couple pictures of Brazilian Y-Blocks with their original alternators. Maybe that could give you an idea for the brackets... If you think this could make thigs easier, I can try to take pictures of the brackets only. I think I have those brackets somewhere here in my garage...
Best regards,
Lucas (Lobo)
Best regards,
Lucas (Lobo)
1 wire alternators
This came out of the "Best of Tech" magazine, issue winter of 2003, and I will just quote it.
"...the elimination of the field and stator circuits used in a traditional multi-wire hookup means that a one wire alternator does not turn on automatically when the engine starts because it has no way of sensing the battery's demand. To get the alternator to start charging, or excite, the driver must rev the engine to the rpm where the alternator turns on. The rpm this occurs at depends on the alternator/crankshaft pulley ratio as well as teh nuances of the windings, so two alternators with the same ratio may still self-excite at different rpm, and it could be anywhere from under 1,000 rpm to 2,500 depending upon your combination. When selecting any one wire alternator, make sure you get a model that stays on once it is excited. Some less expensive brands may only charge when the rpm is at or above the starting rpm point."
FYI Mike
FYI Mike
Yes, that's almost it.
We had 272's and 292's.
The last year Ford used Y-Blocks on cars and trucks was 1975. But there was an alcohol version (I've never seen one of theses, and I found out about it not long ago) that was produced up to the early 80's. They were used on big trucks (special orders). Well... At least that's what I've been told about these alcohol engines...
Lucas (Lobo)
Lucas (Lobo)
