Shortbed vs Bronco
Finding a solid 78-79 Bronco is the only thing rare about them! They were and still are a very popular vehicle. I've still got the 78 my dad bought new, goes great in no matter what you throw at it. Mud, snow, etc. Only real problem is the cancer eating away at the body and now the frame.
As far as a pickup vs Bronco as said a lot comes down to what/and how much you want to haul.
I think the shortbed pickup wheelbase is a little longer than the Broncos, but probably not by much. I doubt it would make much of a difference, since they're both wide vehicles and don't always fit down really tight trails as easily as a Jeep or early model Bronco. For me the width seems more critical than the length, within reason. Now my crewcab longbed F350 is a hard one to fit into any tight space...
Yeah. I've seen pickup bodies mounted on a Bronco frame. You have to shorten the bed to make it work, but it looks pretty darn good, in my opinion. I've also seen Chevy pickup bodies on a Blazer frame. I'm not sure what the exact difference in length is though. The shorter wheelbase that the Bronco has, seems to have better traction to the rear wheels then a standard short wheelbase truck. I can go places without being in 4wd then some trucks that are. Also you have less sticking out behind the rear wheels. You can have a better angle of departure.
A fullsize Bronco has 104" wheelbase, as 79driver stated. An Explorer 4-door has 107" wheelbase, so the Bronco is very short. That helps the Bronco turning radius and ability to not be high centered as easily. The problem is that it also thus has a short rear driveshaft, so any lift taller than 4" can tend to create u-joint angle issues. I had two lifted Broncos during a 10 year period, I loved them, especially without the top in summer
If you are going to tow at all, get the truck and it's bed. If you want passengers or plan on sleeping in the woods, get the Bronco. With screens on the side windows, a Bronco is pretty nice. A toolbox that bolts to the frame through the rear floor makes a very nice and secure place to put your trail tools.
Plus, in a Bronco you can fit a 60" high lift jack down the pass. side of the cabin and keep it clean. Just run a small plate through the wheel well (assuming a 78-79 is built the same there as a mid 80s) and attach it to another bracket coming off the door jamb. I put the base first/behind the pass. seat in case of an accident so the handle assemble does not go flying down the length and hit a passenger in case you forget to lock it.
Broncos will always have a higher resale value.
mustang is right most of the guys that can even stretch the front axles out some. The short wheel bases are great on trails but in the mud a long wheel base is better. Look at it this way if you had to follow Pro through the pit, and hit a place where he spun a little you would put all 4 of your tires in one of his tire marks with the short wheel base.
