1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Towing with a lifted truck?
Old 12-28-2015, 11:51 PM
jimmystoys's Avatar
jimmystoys
jimmystoys is offline
I've been towing with my lift since new, about 92k. 12" drop, solid steel. Air bags help a lot.
Old 12-29-2015, 01:01 AM
Will Bite's Avatar
Will Bite
Will Bite is offline
Originally Posted by Dave Sponaugle
Another thing to look at is the big drop hitches are not rated for the weight that the straight hitches are. I have never seen a six inch drop hitch rated for over 7,000 pounds, lots of them are only rated for 5,000 pounds.
10000 lb rated.
Old 12-29-2015, 07:07 AM
projectnitemare's Avatar
projectnitemare
projectnitemare is offline
Originally Posted by Will Bite
10000 lb rated.
I see a lot of hitches like those rated at 10k plus. I wouldn't trust those turds for much. You have your tongue weight and the trailer pull only supported by 2 pins. Granted they are in double shear but I've never been comfortable with that. I suggest Anderson drop hitches being the adjustment section is a structure that slides around the drop tube. They probably are the most expensive but definitely a better design.
Old 12-29-2015, 05:54 PM
Will Bite's Avatar
Will Bite
Had mine for 3+ years and never had a problem and I'll guess I've been over on a couple of occasions. I was just showing that there are hitches out there.
MTP55
10-09-2017 06:31 PM
Chucko1404
04-20-2017 12:11 PM
chazms
17
04-17-2017 09:27 AM
kickstand03263
23
10-13-2016 05:59 AM
CHawkinVA
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
13
04-10-2016 07:56 PM
Quick Reply: Towing with a lifted truck?
