Maintainance discovery of oil in transmission?!?!?!
I took my ranger down and got the oil changed and the raditator flushed. They pulled the fill plug on my manual transmission and discovered it had 10w30 engine oil in the transmission instead of ATF. They flushed it and put ATF back in it. Can I expect any problems from the use of 10w30 instead of ATF?
It does shift better now that it doesn't have to churn friggin' peanut butter for tranny fluid.
BTW. this is a 5speed/2.3L combo.
I've heard of people using motor oil in the M5OD trannies in an attempt to get them to shift *better*. This usually comes about in an effort to get them to try to shift better when going into first, second, and/or reverse. I do have to wonder how they could so readily nail down the viscosity of what they drained out of your tranny . How could they tell it was 10W30 and not 30w, 40w, 10w40, 5w20, etc? And I would love to be able to look them in the eye as they answered this question .
It was most likely just wore out atf. atf turns dark black and thickens in thease tranny's after about 30-40k some times less. I just changed it in my 99 that I just bought. Has 77k on it and I don't know if it was ever changed. CAme out black and thick but I could still tell it was atf by the smell.
Dan
Dan
Thanks everybody for the advice. It does indeed shift better, less force is needed to put it into gear. It never needed excessive force, but I've always noticed that it needed to be pushed a little harder than all the other manuals I've driven. Now that it has ATF in it, it's drops into gear without having to kinda wrestle with it.
I highly doubt even if it was 10W30 that it did any damage. I've ALWAYS ran non detergent motor oil in my 91 with the 2.3 M5OD tranny, and that combo is about to kick over 312,000 miles. I've never had any problems with it. I know people who run straight 80 or 90 weight in that same tranny without any problems.
