Temp. Sending Unit 1990 F150
I lost my sending unit on my 1990 5.0L and after I replaced the unit my gauge now reads 2/3rds of the scale. Motor seems to be about the same temperature as before unit failure and the gauge was at bottom 1/3 of scale. Are the thermocouples (sending units) calibrated for the gauges? Also, I grounded the sending unit temporarily to make sure my panel gauge was working I did not leave it grounded long enough to even reach full scale so I do not think I damaged the gauge.
If you have a VOM, you can check the resistance at different temperatures. Attach the leads to the sender and place it in a pan of water. Then place a thermometer in the water. Here are a couple of readings at higher temps. 104=1459ohm, 140=667ohm, 176=332ohm, 212=177ohm. Remember the temp of the water inside your engine gets hotter than 212, but you can't test in an open vessel because boiling water won't get hotter than 212. If your readings are significantly different than these, then you have the wrong sender. Good luck.
jrockdiddy
07-23-2015 09:44 AM
bmoran4
08-30-2011 05:01 PM
