Block Heater ?
Block Heater ?
I got a 96 f 150 302 auto. It got cool out last night and my truck barely started. I was thinking of getting a block heater for it and the only freeze plug I can see is the passenger side above the starter( I believe it to be 1 1/2 in size this sound right) . Is this the correct one for putting in the block heater and if so how hard is it to get the freeze plug out..
Other options I have seen are, heated Dipstic, heater hose circulating tank, One that splices in lower Radiator hose, a magnetic one for the oil pan, anyone know if any of these are better than a block heater and some are definately easier to install. Any help appreciated or any other options please let me know..
Thanks Alot
Thanks Alot
Jeg's has a block heater for the freeze plug that's $25....goes in that passanger side rear freeze plug.
To get the plug out, use a screw driver and hammer, tap one side so the plug kinda spins around, then use a pair of pliers to pull it out. Gotta flush out the radiator fluid first though.
51PanelMan
16
04-10-2018 11:08 PM
hukdonquack
243
07-16-2008 06:40 AM
HENDEL JR
01-25-2006 09:51 AM
