Just bought a 99 Explorer XLT, what should I look out for?
I have a '99 with the 4.0 sohc. also had the O ring intake manifold problem (I think everyone has it). Another common problem is the air bag light flashing 3-7. It's a connection under the passenger seat that comes loose, usually from someone kicking it (my mother in law) in the back seat.
That's one of the 1st problems I was able to fix (the dealer wanted 2-300 bucks for a new harness) thanks to the many great people on this board.
I also learned a lot about oil & filters, where the tissue box goes, (some of you will get that one), & where to have my mother in law sit.
Rick
Rick
Well ... intake o-rings leak cause bad idle in the cold, transmission valve body seals cause slipping, IAC for idle problems, make sure the Firestones got taken off, if you have the combo cd/cass stereo the display is a problem, ball joints, abs light is probably the rear diff sensor, air bag fault 36 and 37 are the connectors under the front seats, and no heat or no a/c is probably the blend door (message sticky on the main page). Good luck.
VIN on OASIS
anoyinguy,
That would be great. I will send you my VIN off list.
Ed
Ed
Originally Posted by thtanoyinguy
look out for the o-rings in the intake, the timing chain rattle,and balljoints.i work for ford so if you want i can look up your VIN on oasis and tell you what has been done to it and if it has any recalls or tsb's.
