You can't adjust it, when the clutch feels weak you may have a bad leaking slave,
or the clutch disk it's wear out, if you gonna replace the slave cylinder go ahead
and do the clutch too, because you still have to remove the tran to get to the slave.
what a pain in the a..??
Thanks everyone. This clutch is about 9 months old, so I'll see about the slave cylinder.
it sucks when you have to work double!!, but when I took mine for clutch
they told me the slave cylinder was ok, about 60%, and the said if the slave
goes bad in 6mos or so I'm gonna have to pay again to remove the tran,
so for $60 + I want to have peace in mind
