'94 Ranger SuperCab Driveshaft Bearing
Old 05-21-2000, 08:52 PM
rokhopper's Avatar
rokhopper
rokhopper is offline
The driveshaft bearing (also called a center support bearing) failed on my truck. I replaced it with a unit from a local auto parts store. It was not 100% identical to the factory unit, but seemed to fit well enough. This unit failed after about 500 miles of operation (the bearing itself was pushed out the back of the rubber housing by the front portion of the driveshaft). Assuming I botched the install, I purchased an identical unit from another shop. Fortunately I caught this one before it completely failed, but it was about to do the same thing. Has anyone had any experience with this part, or replacing it? The one(s) I bought fit snugly onto the driveshaft. Is this correct, or is the shaft supposed to sit loose inside the bearing?
Old 06-21-2000, 08:55 AM
upchuck's Avatar
upchuck
upchuck is offline
I own a 95 Ranger SC. Last summer I had to replace what the guy called a hanger bearing. Have had no problems with it since. At first appearance of the problems I thought I was losing my wheels. It only affected the ride at middle speeds.
Old 06-24-2000, 06:39 AM
pajamas's Avatar
pajamas
pajamas is offline
I'd suggest you have the driveshaft balanced or replaced if you have a bearing failure.
Old 06-26-2000, 07:01 PM
broncrick's Avatar
broncrick
broncrick is offline
01-20-2013 02:54 PM
SHOpar
06-21-2009 10:32 AM
braggon
2004 - 2008 F150
20
01-05-2009 12:59 PM
MikeGV
11-28-2004 05:37 PM
Lojack1
11-18-2002 06:47 PM
Quick Reply: '94 Ranger SuperCab Driveshaft Bearing
