90 150, fuse panel locations picture?
Pulled the ignition switch out of an f150 I just recieved, hot wired the coil and jumped the starter but it wont start. I remembered my brother pulled all the fuses, does anyone have a picture or diagram of where the fuses go (under the dash)? Thanks.
Fuse diagram should be in owner's manual; also on inside of fuse panel cover left of steering column I think. May also be in haynes manual. Fuses are numbered in vertical columns starting top right: 1 - 15a, 2 and 3 not used, 4 - 15a, 2nd col -- 5 - 15 a, 6 - 15a, 7 - 15 a, 8 - 15a, 3rd col; 9 - 30a, 10 - 5a, 11 - 15a, 12 - 25a, unnumbered Cir Bkr betw 12 and 13, 13 - not used, 4th col; 14 - 25a (Bronco tailgate window), 15 - 10a, 16 - 30a, 5th col; 17 - 20a, 18 - 15a. 4th and 5th cols are located under turn signal flasher. Another Cir Bkr is listed between 14 and 15 fuses. Hope this helps.
I already found it with pictures, http://www.autozone.com/servlet/UiBr...3d800a39c3.jsp
Thanks a lot anyways.
BaronVonAutomatc
Electrical Systems/Wiring
04-20-2010 06:38 AM
stevec999
08-14-2002 11:45 AM
