ceramic coating for headers?
Old 12-17-2004, 09:46 AM
imlowr2's Avatar
imlowr2
imlowr2 is offline
AX, I did electrostatic plating for 7 years. I stand corrected, you can plate stainless, but it's very costly if your going to go through the processes of chemical treatment to the metal. I was thinking the metal itself has no magnetic properties and therefore makes it hard to conduct electricity for the nickel/ chrome etc to adhere to the metal. Thanks for clearing that up though. I'm with you, why plate stainless? Just get it buffed out. Looks nice and lasts.
Old 12-17-2004, 11:30 PM
fordor's Avatar
fordor
fordor is offline
Hey Ranger pat where did you get your headers ceramic coated at in west michigan? I live in west michigan and would like to get mine done for my truck.
Thanks,
fordor
Old 05-18-2005, 01:09 PM
fiftford's Avatar
fiftford
fiftford is offline
My trucks been sitting for awhile. The headers have some rust on them now including a few pinholes. I'm getting the truck back on the road and was going to buy new headers, but I'd prefer to have mine ceramic coated (they were custom welded). Would the coating work over surface rust and cover the pinholes, or am I out of luck?
Old 05-18-2005, 01:13 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
They have to clean the rust off.. I don't know about covering holes.
Sam
Old 05-18-2005, 02:15 PM
Randy Jack's Avatar
Randy Jack
Randy Jack is offline
fiftford - My old headers were very pitted and they turned out well. The finish on them isn't totally smooth like a new set would be, but they work great and look 100% better than they did.
Rust can be cleaned off and pinholes welded closed and ground smooth. Go for it.
Old 05-18-2005, 02:33 PM
fatfenders56's Avatar
fatfenders56
fatfenders56 is offline
the voice of $$$$$$$$$$ experience says to have the mounting flange blanchard ground before coating your headers, this will give a much better seal and eliminate leaks around the flange. good luck
Old 05-18-2005, 08:23 PM
fiftford's Avatar
fiftford
fiftford is offline
Thanks all. I think it's worth a shot.
Old 05-25-2005, 02:12 AM
OldSchoolRodz's Avatar
OldSchoolRodz
OldSchoolRodz is offline
Red face Say What?
Hey Fats, can you educate me about "blanchard ground" and would this apply if I were having a pr. of Ramshorns Ceramic coated? Thx. David
Old 05-25-2005, 08:56 AM
Randy Jack's Avatar
Randy Jack
Deuced - Blanchard grinding is a machining method to apply a very flat surface to the header flanges. It uses a very large flat grinding disk to average a surface into a flat plane. A milling machine or other kinds of grinders can also be used. It is just important to get the flange as flat as possible for best sealing.
Old 05-25-2005, 08:59 AM
fatfenders56
David, blanchard ground refers to a method of planing a large surface to a very close tolerance, think of it as planing a cylinder head or an intake manifold. There are shops here in Tucson who can do it. I believe Townsend performance could do the rams horns if they really need to be done.
Branded
13
01-16-2014 08:27 AM
joeyd61
07-05-2012 03:00 PM
Myfreeford
Oregon Chapter
02-05-2011 10:12 PM
sandmanf250
WTB - Parts & other
07-09-2010 05:26 PM
Garrett003
07-13-2006 03:40 PM
Quick Reply: ceramic coating for headers?
