Bilsteins are now available for 04-05 F150's
Just saw it in this weeks Autoweek -- an ad saying they are now available --
I have had both the Bilstein and Edelbrocks on a 2001 Supercrew -- (yes I have had two of them) -- Bilstein firmer - much much better tower --- Edelbrock 1/2 way from Bilstein to original equipment ride - handled big bumps and potholes better --- both provided much better motion control than stock --
FYI one of the F150's at 24k had two of the shocks that were gone
Originally Posted by YOMAN
Awesome!
Does Bisetin shock came with coil for front?
Thanks!
YOMAN!
Thanks!
YOMAN!
This brings up a related question, and possibly a dumb one, havent really thought about it yet...is the ride quality of a shock affected by a leveling kit? I am getting a kit for Xmas and like the thought of the bilsteins down the road, but should I consider other shocks with the leveling kit? I think I am getting the protechezlift 2.5" kit.
ok finally question, how the heck did you remove coil off from shock? maybe write some step to step so other view will read and learn how to's ??
Front Suspension — 4x4
DISASSEMBLY AND ASSEMBLY
1. Remove the shock absorber and spring
assembly from vehicle.
2. Using a suitable spring compressor, compress Shock Absorber and Spring
the spring until the tension is released from the Assembly
shock absorber.
3. NOTE: While holding the flats of the washer, remove the nut.
Remove the shock absorber-to-upper mount nut
and the upper shock mount.
4. Remove the insulator.
5. Remove the dust tube.
6. Remove the coil spring from the shock absorber.
Disassembly and Assembly
To assemble, reverse the disassembly procedure.
• To install, tighten to 30 Nm (22 lb-ft).
