Engine Vacuum
The term "engine vacuum" refers to the difference between outside atmospheric pressure and the amount of vacuum present in the intake manifold. The pistons in the engine serve as suction pumps that create this pressure difference.
Normal Engine Operation: At idling speed, an engine at sea level should show a steady vacuum reading between 14 in. and 22 in. Hg. A quick opening and closing of the throttle should cause the vacuum to drop below 5 in., then rebound to 23 in. or more.
Find a vacuum port on your carburetor or intake manifold and check to insure that you have steady vacuum at the stated levels. If so, your vacuum brake booster will operate properly.
If the vacuum is not steady, the gauge needle behavior tells a story of engine condition. There are charts available to interpret your gauge readings.
ford fisherman
1983 - 2012 Ranger & B-Series
02-03-2015 05:58 PM
78 & 87 Super Cab
11-07-2013 12:44 PM
64F-100
10-12-2010 12:31 PM
