Radiator going
Old 12-07-2004, 05:28 PM
Dustin_86's Avatar
Dustin_86
Dustin_86 is offline
Question Radiator going
I looked at the radiator on my 86 which has the funky side flowing tubes(Gm) like and about mid radiator thier is what looks like white crud on one of the rows. A guy at a rad shop told me that is the tanks leaking. But it does not spray or use coolant so "How much time she got left? Can just that one spot be fixed or does the tanks have to be redone? I called Autozone and The guy confused me with "does it have standard or super cooling" I don't know it's just a 86 F150 Long bed 2wd ext cab auto w/factor air and a EFI 302. How much would it cost me to have new tanks put on it if it can't be fixed?
Dustin
Old 12-07-2004, 06:16 PM
F150'89's Avatar
F150'89
F150'89 is offline
The radiator could last 1 day, 1 week or 1 year, its hard to tell. The standard cool rad will be a 2 core and the super cool will be 3 or 4 core. Having the old radiator retanked could cost the same as a new one, the new one from Auto Zone will have a life time warranty.
Old 12-07-2004, 07:04 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
CowboyBilly9Mile is offline
My experience with letting people solder on radiators/install new cores with old tanks is that they are never as reliable and long lasting as new. As for life, well, they are an item subject to thermal fatigue. Every hot/cold cycle fatigues the joints a bit. Myself, I like reliable so I prefer to simply replace them around 175,000 - 200,000 miles. However, I usually put some miles on each time I drive. Lower miles with more hot/cold cycles and I'd lower that miles number.
Old 12-08-2004, 04:22 AM
sixpack2639's Avatar
sixpack2639
sixpack2639 is offline
Dustin, If your radiator has the plastic tanks, (which I think it does), it is not repairable if the leak is any where close to the tank. I just replaced the rad in my 95 F150 due to a leak at the tank seal. Got the new one from http://www.autoradiatorsdirect.com for $121. w/ free shipping. Hope that helps. Carl
Old 12-08-2004, 05:12 PM
Dustin_86's Avatar
Dustin_86
Thank you so much carl,
I almost want to send you a Christmas present The closest offer I got to that link was $170 and I'm a POOR high school kid. They said $132.00
Hows that Gieco commerical go "You just saved me a bunch of money on my RADIATOR" I will have so save a little but that is ALOT cheaper than the others.
It is not split at the tanks, it is at one of the cross-flowing tubes.
Where the tanks join the fined tubes it looks perfect just one of the tubes has whiteness on it.
Dustin
Dustin_86
Oil & Lubrication
10-14-2006 06:02 AM
Dustin_86
06-21-2005 08:50 AM
Dustin_86
Ford vs The Competition
02-03-2004 08:08 PM
Dustin_86
Paint & Bodywork
01-02-2004 06:03 AM
Dustin_86
29
10-26-2003 01:54 AM
Quick Reply: Radiator going
