1984 351 Ho ?????
Old 12-02-2004, 09:01 PM
captbkoch's Avatar
captbkoch
captbkoch is offline
Smile 1984 351 Ho ?????
Hello all, I just became the proud owner of a 1984 F-150 with 60k original miles. It has a 5.8 ltr HO , What is the horsepower of this? Its 2 tone blue and silver, blue velor interior with wood panel (fake)doors, A/C , cruise control. I dont know yet if its a Xl or Xlt , any help??? After I get it home this weekend I'll try and post a pic!!! Thanks in advance for your help, Brian
Old 12-03-2004, 05:30 AM
RR4E's Avatar
RR4E
RR4E is offline
XL or XLT tag will be mounted dead center of your dash console...won't be hard to miss. My 81 is an XLT, but missing some possible options from it's year, although I'm not missing power windows much as they tend to screw up more often than work. It does have a/c, dual tanks, and cruise control...good enough for me, along with being 4x4. Is it a Ranger, Explorer, Custom, or non-denoted cab package?(will be attached to the F150 tag on the side of the fender as to which)
Old 12-05-2004, 08:17 AM
captbkoch's Avatar
captbkoch
The is no designation on the exterior other than f-150? The velor intirior ,wood panel doors, and cruise are from which model? no power windows no rear slider . I gues I'll be able to tell more as I pick it up in a few hours. Brian
Old 12-05-2004, 08:19 AM
Lee Lichterman's Avatar
Lee Lichterman
Lee Lichterman is offline
Your bezel around the heater controls/radio and clock should say XLT on it with those options I would imagine. If not, it will say XL or just be plain. I would bet it is an XLT though.
The no power windows is odd though. With all teh other options, I wonder why not that?
Lee
Old 12-05-2004, 08:32 AM
8 Lugs's Avatar
8 Lugs
8 Lugs is offline
With those options, if it has carpeting, it's an XLT
If it has a floor mat, it's an XL
Steve G.
Old 12-05-2004, 08:45 AM
captbkoch's Avatar
captbkoch
The truck is from Minnasota sp, also has block heater, If I remember it has rubber mat over carpet, Dad had a 81 f250 xlt lariat camper special crew cab, optioned almost identicle to this one. It to had no power windows. Does the velour seat tell us any thing?
Old 12-05-2004, 02:20 PM
SSCX2's Avatar
SSCX2
SSCX2 is offline
Nope, the XL-XLT packages were mostly trim. Most likely with the engine and the interior you have its an XLT but its hard to say for sure.
You asked about HP numbers all the stock 5.8L's tend to be around 225hp, that's at the crank. The rear wheels see 170ish.
Old 12-05-2004, 10:48 PM
justshootme84's Avatar
justshootme84
justshootme84 is offline
Here's the specs for the 351W's. The H.O. has 210HP@4000RPM.
engine specs
Sounds like an XLT P/U similar to my Bronco.
Old 12-06-2004, 01:31 PM
SSCX2's Avatar
SSCX2
SSCX2 is offline
engine specs
Good chart!
Old 12-06-2004, 06:48 PM
captbkoch's Avatar
captbkoch
This thing is ok on the highway but wont get out of its own way around town! the drive home was 96 miles door to door, driven between 65-70 MPH maybe slightly more at times. I know its the 3.00 rear ,but come on!!!!! Changed the oil, pcv and air filters before the trip. It has a hole in the muffler, gotten larger after the good blow out trip home. The ex. appears to be stock all the way back, y pipe to single to muffler.Tranny fluid was a light pink . Seems like your getting going good and making power and it shifts !!! argh!!!!
Old 12-06-2004, 11:43 PM
justshootme84
Check to see if it has the original Holley 4180 4BBl carb. If properly tuned, you should be glued to your seat on take-off. I ended up replacing mine due to a worn out accelerator pump and massive gas leak, and it made all the difference. Also check for any vacuum leaks in amongst that spaghetti mess of vacuum lines in front of the carb. A tune-up may also be needed. Good luck!!!
Old 12-07-2004, 09:18 AM
captbkoch's Avatar
captbkoch
It is the stock carb, but there is only 60k miles. Would the pump be bad that soon? The truck runs great at speed ,but hesitates at take off, just feel slike there is no power?? What lines can I remove from the carb??
Old 12-17-2004, 05:47 PM
captbkoch's Avatar
captbkoch
btttttttttttttttt
Old 12-17-2004, 07:19 PM
fordfan302's Avatar
fordfan302
fordfan302 is offline
Are you sure that engine chart is accurate........It says my Ol' Truck only has 139 factory horsepower
Old 12-18-2004, 08:08 AM
captbkoch's Avatar
captbkoch
Thats the difference between 302 and 351 HO!!!!!
Quick Reply: 1984 351 Ho ?????
