05' Brake Controller Doesn't Work For ...........
FYI, the electronic Trailer Brake Controller, TBC as they call it, does not work with electric-over-hydraulic brake systems. I do not recall reading that in any of their literature but they do print it in the manual. Problem is I bought the truck before I read the manual. Now the option I had to have is useless for towing my boat. Does anyone know if an electric-over-hydraulic system can be converted to a surge brake system?
Note to self: change signature, 05 F-250 LARIAT CC 4X4 SB DARK STONE w/ ARIZONA BEIGE ACCENT
My question is what does it matter if it is straight electric or electric/hydro? It is just sending a signal to the brakes or a on the ele/hydro signal to an accuator isn't it? Then the accuator pushes on a master cylinder....I guess I don't know why it wouldn't work. Have you tried it yet? Let me know if you have, cause I was looking at converting my surge to electic/hydro because the surge keep failing. Don't want to waste my money converting.
I have tried it. It does not work. The one Ford is using is supposedly made by Prodigy and is not compatible with electric over hydraulic brakes. I did not know that when I bought the truck. I went to a trailer dealer today to have the axles serviced and to see what I could do. He said I could add a magnet in the brake system to make the digital contoller work, but he would not recommend doing that on a boat trailer because it is submerged in salt water and would not last. My other option is to add a surge actuator and make it a complete surge brake system. The cost of the conversion is about 450.00. I too have had a lot of problems with surge brakes in the past. I liked the way the electric over hydraulic brakes worked and the adjustability of using the controller. Driveing home from the trailer dealer today I realized I need a trailer brake system that works. Even these heavy trucks have a hard time stopping 9000# + on their own. I guess I have all winter to think about it.
Originally Posted by My4x4Toy
Boats new and trailers new. Yes I am thinking of changing it to surge brakes as you describe so I do not need to use or modify the brake controller.
I currently pull a foutain 31, and had a 25 foot mako and a 28 ft grady white before all with surge brake's. I have never had a problem with them, but you do have to make sure that you wash them out good, brake's and caliber's or rust can make them less effective. Only trouble is backing up if you have a wheel against a curb or in a pothole. You can lock the brake's on the trailer. The trailer I have now has a wire that is connected to the backup lights and when they are on the brake's are locked open. Just my thought but personally I really like the surge brake's.
It would be cheaper to install a second controller. I wanted the built in one because it was "built in". I don't want to add a second one and also have to add another 7 pin connector in the rear. As far as weight distribution, I don't need that with a boat trailer. The engines hanging off the back take a lot of the weight off the tongue. I don't know how many trailers come with this electric over hydraulic sytem. I had never heard of it until my new boat trailer came with it. They did not offer me a choice when I ordered the trailer. I have pretty much decieded to change over to surge brakes, I just wanted others to know about this problem. It's not a total waste, I have a travel trailer that has electric brakes.
I tow boats quite often and I suggest that you convert to Kodiak disc brakes and use a surge actuator that has the integral backup solenoid switch(Atwood makes a good one). I recommend buying Kodiaks cadmium plated rotor with the integral hub and the stainless steel caliper kit. For a boat that size you should be installing 12' brakes on at least two axles. The disc brakes are much easier to keep working as they are easier to wash--and they stop great. That is why we have them on our trucks!
Royce
Royce
