NEW PICS: 35" BFG Mud Terrains
It's a 2" Revtek level kit...saw some others with the same setup (stock wheels, same size tires, 2-2.5" level kit w/ slight rubbing) so decided to go with it...cuz i like the fx4 stock 18s so well...worth it to me...clearence is fine...only problem is the occasional rub on some (not all) full hard turns....where I got the tires said the stock wheels would be fine also
JS66: how would a wider wheel decrease or eliminate the rubbing? what do you mean by offset? only rubbing i can see or feel now is on the lower part of the front driver's side frame..about a 3" wide rub mark...only on a full right turn on certain road slopes...
How long has BFG been building Mud Terrain's for 18" rims. The truck looks good and 35" rubber fills those wheel wells nicely. I hope the guy that mounted tires that need 8.5-11" rims on 7.5" rims is going to stand behind the tire wear. They are 2910lbs at 50lbs. How much air are you running in them?
Now if BFG is building a 35" mud tire why can't they build a 35" all terrain or highway tire for 18" rims? That's why I ask how long have they been building these??
Originally Posted by ctfordguy
I have the same tires only in a 33" and the buzz on the highway is barely noticable. I tell my friends the truck was so quiet stock that with the tires, intake, and exhaust it sounds 'normal', just like my old truck.
By the way, I LOVE the way those 35;s look but I don't know how they squeezed them on 7.5 inch wide wheels. I would love to get them but can't afford them AND a lift (I don't like rubbing or the leveling look).
