wind noise
#46
I had my truck for about 5 months before the wind noise started coming from the windshield area one day. l decided to try to find where the noise was coming from for myself before taking it to the dealer. I ran a peice of masking tape along the bottom of the metal trim piece that runs across the top of the windshield (covering the gap between the trim piece and the glass) and the noise completey went away. So, I went to the dealer and told the service writer exactly what I had found. When I picked the truck up, they said that they had heard the noise and resealed the windshield and that took care of it. Well, apparently they didn't drive the truck after they did the work because the noise was still there. I took a look at what they had done when I got home. They only ran sealant across the top of the windshield on the inside of the truck (I could smell the sealant inside the truck) and didn't touch the outside of the windshield where I had found the source of the problem.
The old saying "If you want the job done right, do it yourself" came to mind (and I was leaving town in the truck on a long trip the next morning) so I decided to fix it myself. I ran a very small bead of black silicone in the gap between the metal trim piece and the windheild and the noise completely went away. This bead is probably only 1/16 wide so it is nearly impossible to see and there was no cleanup. If it shrinks over time and starts making the noise again, I'll just take 5 minutes and run another bead, that is unless Ford comes up with a more professional fix to the problem......
#47
Ftkcignusx1, well it’s a good thing I don’t write repair manuals for a living. Let me go thru this using your terms. When I stated seal under neath I meant under the "rubber molding". Then fill on top of rubber molding closing the gap. At this point you should have no gap between the "decorative molding" and roof line. All repair takes place under and on top of "rubber molding". Also when I injected silicone under rubber molding it was undetectable by eye. As for the black silicone on top of rubber molding, the job came out real nice, all most looks factory. My truck is black that might also help with the look. I’m unclear on your fix. Is your wind noise gone? Also I think the silicone will last a long time, they use silicone to install the windshields from the factory. Next time your at the dealership take a look at the F-250 gasket around window .That gasket looks like a good fix for F-150"s. As for Ford changing to something like that I’m not sure that will happen. Our problem doesn’t seam as wide spread as the dreaded vibration problem. I’m thankful I don"t have to deal with that problem. Well I hope this clears it up for you let me know.
#49
#50
Originally Posted by 79REK
BTW, I ran a very small bead of black silicone between the trim piece and the glass. I didn't pull the trim piece up or anything, just sealed the gap. I also didn't put any silicone under or around the rubber seal above the trim piece.
#52
#53
wind noise is back
My wind noise is back - it's been steadily getting worse over the past month or two. I'm due for an oil change and am having some shudder when I accelerate through turns from a stop so I'll be in the shop anyway. Hopefully they can figure something out this time. If not, I'm going to have at it myself as you guys have described.
#54
#56
#57
I have the wind noise as well. '04 s-crew. My truck is fine until I hit 65-70 mph. the noise will be on one side or the other, upper corner of windshield. Which side the noise is on is determed by outside wind direction. Occasionlly, there will be some noise top center of windshield. Very annoying. Otherwise, great truck!
#58
#60
just got the truck from the dealer today
suprise the wind noise still there, actually is even worst now then before
the dealer change to a new windshield and claim it should take care of the problem
guess not, not to mention glass where all over the truck
how many times would it takes before the dealer give up and buy back your truck?
does it have to be the same dealer where it was purchased from?
thanks
thanks
