1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
NEW F350 Lariat Dually Ignition LOCK
Old 11-26-2004, 02:23 PM
synergy46's Avatar
synergy46
synergy46 is offline
Talking NEW F350 Lariat Dually Ignition LOCK
I haven't owned a Ford since 1976. (quality control issues). But, the 2005 F350 was just too compelling. Here is a recent experience and solution.
MY New f350, dually, lariat, 4x4, with only 153 miles on it suddenly had a locked ignition. Just a few minutes before, I was loading cd's into the player. 20 minutes after that I could insert the key but NOT turn the key. The steering wheel was solidly locked.
Solution: While the wheel may 'seem' like it is locked, it really isn't. I just torqued it hard counter clockwise and then the key would work normally. (I am 230 lbs and don't usually have to torque things this hard to get them to work)
Also,......
The 'emergency services' tow truck driver that showed me this little 'trick' told me that Ford Trucks with the keyless entry system sometimes experience a situation where they will not start. The key will turn. The engine will turn over but will not start. His observation was that if you just use your key fob to lock, lock (twice) and then unlock, unlock (twice) the doors it will start.
Thought I would pass this on....
Love my F350!!!!
Old 11-26-2004, 04:54 PM
bgrover's Avatar
bgrover
bgrover is offline
I've had the "locked" ignition on every vehicle I've had in the past 10 years (all Fords). I find it usually happens when I turn the vehicle off with the steering wheel turned to one side or the other. This seems to put some tension on the key and makes it hard to turn. As you found if you pull the wheel one way or the other it will release the key.
Old 11-27-2004, 01:29 PM
etcetera's Avatar
etcetera
etcetera is offline
I think that's the way it's supposed to work. I've experienced it in a Toyota Corolla and a Nissan pickup, both early nineties. I can make my 250 and the wife's escape do it as well.
Eric
Tewkman
1997 - 2003 F150
11-23-2013 09:34 PM
white99
18
09-26-2012 02:51 PM
jack3
02-26-2004 03:20 PM
Quick Reply: NEW F350 Lariat Dually Ignition LOCK
