Bosch Glow Plugs?
hey now. I'm a little farther north its so cold here we don't see much snow I know we were down to -50 wind chill I got my truck start on 7 cylinders(one of them was cracked) and jumped my dads aerostar. motorcraft are better designed for these trucks also don't buy from ford buy them from O'reiliys or autozone. half-price autozone is suppose to carry 8 inthe store all the time.
Originally Posted by nogo73
hey now. I'm a little farther north its so cold here we don't see much snow I know we were down to -50 wind chill.
Autolite are the worst I ever used. Beru are the best. I used bosh also and did not have any premature failure. I change them when they do not light anymore, I do not do preventive change, too expensive. It is easy to see if one is out. When you start below freezing, you will notice when a cylinder is not firing as soon as it starts. It will run rough for a couple of second and then when the cylinder fires, as the air/fuel compress enough to raise the temp, it will do a puff and start to run smoother. To test it, just unplug the wire and check with an ohm tester, it should read zero or very near to.
You can also notice when there is more than one because the more plug busted you have, the shorter your light will be on.
When you find one busted, change it. If you do not change all of them, like I do, you might find another one busting the next day, or at the next start so do not be surprise. If you change them only when they brake you will become an expert at detecting a failing plug. Check them all again and change the busted one, so on so on son, this is the story in the world of glow plugs, they are a pain, and when winter comes in, they light up longer, so they brake more often. Once winter sets in and you have changed the bad apples, normally you should be good for the rest of winter, but again, you never know, so keep on watching for rough iddle at start up. If all glow plugs are good, you want to make sure you have enough juice in your 2 batteries, check one at a time, diesel engigne must turn fast to create enough compression and to warm the mixture to fire up, then check for fuel leak at the lines, water in fuel, bad fuel, heating oil substitute..., if all is ok, well you are in for bigger trouble like injectors, fuel pumps, worn cylinder, busted engine, etc..
Have fun
Have fun
on
1 Post
Bosch Glow Plugs
I used Bosch Plugs and they work great. ONLY ONE THING TO WATCH: MAKE SURE THE PLUGS SAY "MADE IN GERMANY" ON THEM. I once tried the Bosch plugs from Japan and they were no better than the crap they try to sell around here.
Does anyone know who sells the OEM Berus that are made in Italy? Can't find anybody that sells them in Western Canada.
Bosch GP's
I use them and so far no problems at all, I also use a manual switch since my controller is shot, I usually fire them for 5 seconds before the truck comes to life maybe a little more when its cold outside.Like some members I have tried different brands for the last four years and I have had the best performances with the Bosch (made in Germany) plugs.
Saigon
Saigon
