1960 4x4 f-250 steering box help
Need help. I am looking at putting in a stock steering box in my 60 ford 4x4 f-250. I don't have the original box.
Is there a difference between the 2 wheel drive and 4 wheel drive steering boxes? According to my 57-63 parts and accessories catalog:
4 wheel dirve
Steering gear assy: B9TT- 3504-A
Shaft and worm: B7Y 3524- A
Housing assy: B9TT-3548-A
Sector Shaft: B7T -3575-C
To make it more confusing I cross referenced and found that some parts on the 59/60 f350, f500,f600 have some of the same part numbers for the 4x4:
Shaft and worm
upper and lower bearing cups
bearing worm roller type
Sector shaft was different
Could I modify a 2 wheel drive box to accomodate the 4x4 components or should I just put in a 2 wheel drive box and not worry?
Appreciate any help.
4 wheel dirve
Shaft and worm
Last edited by idaho211; 11-10-2004 at 12:27 PM. Reason: when typed looks different then when posted
The prior owner "modified" it with a poor fitting power steering assembly so I don't have the original box. I have some used 2 wheel drive steering boxes and wondered if it would work. Did you rebuild your steering box? Is the sector shaft roller the same as a 2 wheel drive so if I find a used one I can rebuild it? Thank you for your reply.
