1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Bent hitch/rear framerails
Old 11-10-2004, 08:12 PM
drighten's Avatar
drighten
drighten is offline
Dunno. Try www.hitch-web.com . They sell them but I didn't investigate too much as I don't need that much trailer ball. I just remembered seeing them there. I cannot even imagine why anyone would need a 30000 pound capacity trailer ball. Anything that heavy ought to be on a fiver in my opinion, connected to a tractor rig.
I just went over to the Hitch web, and I think these ***** are for gooseneck setups. These have a capacity of 25K and 30K.
Old 11-10-2004, 08:15 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
Just looked at mine its an 8 ton pintle with a 12k ball..
Old 11-10-2004, 09:03 PM
SoCalDesertRider's Avatar
SoCalDesertRider
SoCalDesertRider is offline
12K is the highest rated 2" hitch ball I've seen. I have a 10K with a 1.25" dia shank. The 2-5/16 ***** go way up there like was posted and I imagine would be used for a gooseneck trailer. I can imagine an F550 pulling a 25K gooseneck...
Old 11-11-2004, 06:45 AM
SMiller's Avatar
SMiller
SMiller is offline
On Reese's web-site it rates there Titan at 14,000lbs, and yes I would pull that behind the truck, friend has a 16,000lbs pintle trailer, he does it all the time.
Old 11-11-2004, 06:51 AM
99f350sd's Avatar
99f350sd
99f350sd is offline
I have the same pintle but the ball is only rated for 12k..I was looking for a new ball but its the max I can go I think..
Old 11-11-2004, 08:16 AM
LK's Avatar
LK
LK is offline
Originally Posted by 79oneton
Where's this mud pit, I"d like to give it a go before everything freezes up. I'm from central mich area. thanks
It's on the western side of the state, under the power lines perhaps 3-5 miles east/southeast of Rothbury. I could try to give directions, but it'd be pretty difficult - it's sort of one of those places that I know where it is and can drive to it, but giving someone else directions would be difficult. The nearest road is probably McKinley Road, but I'm not 100% sure.
Another spot in western lower Michigan is the area around firetower hill, which is northeast of Crystal Valley. A lot of people come out to try to climb the backside of the hill, but there are also a few mud holes in the area...mainly to the north or northeast. Once again, it's tough to describe where they are - but if you have a Michigan Gazetteer, I think it shows the tower and the state/federal land around it. The easiest thing is probably just to go to that area and start exploring the different trails...there are quite a few of them around there, and many of the folks in this area go there to off-road.
There's also Silver Lake, of course...I don't live all that far from there, but I've never really spent any time there. My trucks tend to be too heavy to work well in sand...though apparently I'm not having good luck with mud either. Maybe I should ignore the mud and build a dune buggy to play in the sand...
As far as the hitch question, my large farm trailer uses a 2 5/16" ball - and I use a 1 1/4" shank gooseneck hitch ball, rated at something like 25K. My trailer is only 10K-12K, but I had a tough time finding one rated high enough without going to the gooseneck ball. Then, once I found the ball, I had a heck of a time finding a 4" drop hitch rated for anywhere near that kind of weight.
The new Superduty uses a 2 1/2" hitch, IIRC - and since it has a very high weight rating, we might start seeing more high-capacity hitch setups.
LK
monsterbaby
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
01-04-2016 06:23 PM
linus72
15
05-06-2012 03:53 PM
smashclash
11-06-2010 07:52 AM
BlueOvalBud
13
09-30-2010 09:12 PM
LK
08-10-2001 07:55 AM
Quick Reply: Bent hitch/rear framerails
