Ranger 94 - stock fog lamp replacement
I am looking for an alternative to the two fog lamps mounted in my plastic vanity piece below my bumber,as the stock price of these fog lamps is riduculous.
There does not seem to be an aftermarket alternative and the stock lamps will not allow you to replace the bulb, I am looking for something that will go through the mounting plate, with a bolt to mount to plate on lamp body.
Preferablly with a scree for protection, and with replaceable bulbs.
What is the best for fog, yellow or white??
Originally Posted by exstoker
.......................the stock lamps will not allow you to replace the bulb.....................
On a side note, I've found that the glue that holds the glass to the back of the lamp likes to deteroriate over time. While you have the lamp out and with your hands, try to pull/rotate the glass from the base. If it breaks free, clean the mating surfaces and secure the glass to the base with Permatex black. And while you're at it, I'd check the other one too. There's enough Rangers driving around out there with missing glass and messed up fog lights.
