Squealing and screeching on morning startup
HI, I have a 2002 Ford Ranger 3.0L V6 5MOD with about 45000 miles and when I start it up in the mornings if its wet or cold out, there is a terrible screeching/squealing noise that comes from under the hood. It seems to be around the belts/fan area (obvious?), but I can't specifically target it. It lasts for 20-60 seconds (sometimes a little longer if its real cold or wet out) and then goes away. Is this a sign that some belts need replacing or a fan problem? How often do they normally need to be replaced? Any ideas why it really only happens in response to cold or wet? Any suggestions on figuring out the problem or what to do? Thanks much!
I had that same noise every so often on my truck then I had my belt changed about 2 months ago. It has just recently started making the same noise again so this problem must be a pulley related problem. I have it narrowed down to one pulley in particular thats making the noise, its the top pulley on the drivers side for me. I found this when i sprayed some belt lube on this pulley and the noise immediately stopped and went away for about a week but then came back. I guess i should try to clean it as well.
This seems to be a common problem for the 3.0. Look to this post for a little additional help...... http://www.fordtrucks.com/forums/sho...d.php?t=294701
