Aluminum Driveshafts?? And lower gears....
Does anyone make an aluminum driveshaft for our trucks? I want to do either 4.10s or 4.56s but I don't want to increase the already slight vibe that I contribute to the driveshaft. A quality built, well balanced aluminum driveshaft that weighs 1/2 as much as stock would be a nice upgrade.
Also, does anyone know if any company makes 4.30 gears for our trucks? The 4.56 is a tad tall for stock tires, and the 4.10 will be a very minimal change for a $1000+ investment (4WD).
Thanks!
Thanks!
Well, the 9.75 rear has almost the same gear selection as the 8.8, the problem is the front diff on 4WD models. It's a reverse rotation 8.8. I found 4.30s for the 9.75, but only 4.10 and 4.56s for the reverse rotation 8.8.
I never knew the older F150s had aluminum driveshafts. That sucks! On a mustang, the stock driveshaft is nearly 2 times heavier than the Ford Racing aluminum, which happens to be .5" larger.
