Lack of power or am i expecting too much
#31
its cool to smoke the tires some times but i feal that i have alot more fun
in the grass lol
I have this big pach of grass on the other side of my road infront of my house
and i allways burn out in it
I like haven the backend slide around
and my trucks backend hops alot to i would like to stop that :?
in the grass lol
#34
the reason you can burn them in reverse is because of gearing...in the olden days before horsepower was very high, cars used to have to go up hills in reverse. The transmission itself is regeared rather highly for reverse compared to 1st and 2nd gear. Btw, your power band doesn't really take off until about 2000-2500 rpm...that is why you can't get a burnout, if you don't like your tranny, put it in neutral and rev the motor to about 3000 rpm, then shift to drive. You'll kill the tranny after a few times of doing this, but you should get an impressive burnout
#35
#39
I meant the limited slip for a post above this one, the truck that wouldn't spin the tires had the limited slip rearend and I was pointing out that it would contribute greatly to traction and make it harder to spin the tires, I'm not sure why it came up as a reply to your guys post. Sorry for the confusion.
Mike
Mike
#41
#42
Burnouts
The reason your truck burns out in reverse and not in first is because of weight transfer. Anyone that has burned out in a front wheel drive car knows that it'll burn out in first or second, but not in reverse.In fact, one time in my old Subaru(front wheel drive), I could not make it up a snowy hill going forward so I gave up and tried reverse! It worked.
If you can't burn out in your truck why not do an impressive donut? They're much cooler!
ArtsBest
01-30-2013 06:56 PM
