Ignition Lock Cylinder Won't Turn
Old 10-16-2004, 02:18 PM
mc73454's Avatar
mc73454
mc73454 is offline
Exclamation Ignition Lock Cylinder Won't Turn
Hey All,
Got a problem.After driving the F150 the other day,with no problems,and after parking it, I got in it last nite to drive it,and the key won't turn the ignition lock cylinder. Nobody's driven it for a week,and it has sat in the same place for a week.I've tried every key I've got,and they all worked before. HELP! Any ideas??
Thanks!
<!-- / message -->
Old 10-16-2004, 02:47 PM
peppy's Avatar
peppy
peppy is offline
Starting from the easiest......is the wheel locked under stress? Thats the most common cause.
What year?
Old 10-16-2004, 04:32 PM
Chris_ce's Avatar
Chris_ce
Chris_ce is offline
If you are like me take your ranger key out and put the f150 key in. I do this about 3 times a week.
Old 10-16-2004, 10:18 PM
mc73454's Avatar
mc73454
mc73454 is offline
Exclamation
It's a 1988 F-150 4x4.The 4WD is not engaged.The wheels aren't under stress,I made sure of that when I parked it.They are straight with no turning involved.They are not against a curb or rise in the ground.I tried the shifter trick,to no avail. I have sprayed WD-40 in the cylinder and am going to leave it set overnite. I am gonna jack the truck up tomorrow to make sure the tension is completely off the wheels. I'm afraid the cylinder took a dump on me with no warning and now I can't get it to the position where I can change it out. I'm willing to listen to anymore suggestions you may have so as not to have to take the steering column apart. Thanks!!
Old 10-16-2004, 10:23 PM
mike L's Avatar
mike L
mike L is offline
Lock Cylinder
Do you have tilt steering sometimes if you move it up or down then turn the key.
Old 10-16-2004, 10:26 PM
mc73454's Avatar
mc73454
mc73454 is offline
Question 88 Column Question
Is an '88 steering column the type where you can remove the ignition lock without removing the steering wheel,or must the wheel be removed? Thanks
Old 10-16-2004, 10:28 PM
mc73454's Avatar
mc73454
mc73454 is offline
Nope,non-tilt steering.
Old 10-16-2004, 10:34 PM
fefarms's Avatar
fefarms
fefarms is offline
You can get the cylinder out without removing the steering wheel. The problem is, you need a working key to turn the cylinder to the "run" position in order to use a 1/8th drill bit in the hole below the cylider to release the retainer and pull the cylinder out.
Ford locks are not terribly secure. You might be able to get a fistful of Ford keys from a junkyard. Keep trying different keys, I bet one of them will work. If nothing else, lots of different serration patterns will bump the tumblers enough to free any sticky ones so that the correct key works.
A decent locksmith (or even a good amature) should be able to pick the lock.
Old 10-16-2004, 10:40 PM
fefarms's Avatar
fefarms
fefarms is offline
It is possible the tumblers work OK, but the switch won't turn because there are broken parts between the key cylinder and the actual ignition switch. If this is the problem you will have to disassemble the steering column. You should be able to feel the difference between these two possible failure modes -- try rocking the cylinder between "ACC" and "ON". A tumbler problem won't allow much motion. Mechanical prob lems downstream will allow more.
Old 10-16-2004, 10:48 PM
mc73454's Avatar
mc73454
mc73454 is offline
I am not able to get it to the ACC or START/RUN position. It feels as if I am constantly using the wrong key. One thing I noticed is yesterday when I tried to start it,the key went in stiffly,like it was the wrong key.I tried the others I have,which worked previously,and they all felt the same way. The keys seem to be going in more smoothly now.
Old 10-17-2004, 06:27 AM
fefarms's Avatar
fefarms
fefarms is offline
Try holding a light turning pressure against the cylinder as you move the key into and out of the lock cylinder by maybe 1/8 inch or so. This may move the recalcitrant tumbler enough to allow the cylinder to turn, without pushing the others off alignment too much. Basically, you would be trying to pick the lock using the key.
bsetbuilding
25
09-19-2021 08:24 PM
Mandolin83
04-04-2018 06:54 AM
earlybirds
12-03-2016 10:10 PM
dlit
1999 to 2016 Super Duty
07-17-2014 04:03 PM
jimjoebob99
67
11-02-2009 01:09 PM
Quick Reply: Ignition Lock Cylinder Won't Turn
