Air Bag!!
Old 10-16-2004, 10:14 AM
FordTuff1's Avatar
FordTuff1
FordTuff1 is offline
Air Bag!!
My air bag lite wont go off in my 1998 F-150,and it is so annoying it flashes 3 times then stops then flashes 2 times i believe and driving me nutz,i tried disconnecting battery and that didnt work is there anything i can do before i have to bring it to dealer and get hammered over the head in price for them to fix it.Thank to all of you on this matter!!!Keith
Old 10-16-2004, 04:37 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,685 Likes on 1,361 Posts
Here's a listing of a few airbag codes:
12 Low Battery Voltage
13 Air Bag Circuit or Crash Sensor Circuit - Shorted to Ground
21 Safing Sensor - Not Mounted on Vehicle Properly
22 Safing Sensor Output Circuit - Shorted to Battery Voltage
23 Safing Sensor Input Feed/Return Circuit Open
24 Open in Circuit 944B or Low Resistance in Crash Sensor(s)
25 Passenger de-activation switch error.
32 Driver Side Air Bag/Safing Sensor Circuit - High Resistance or Open
33 Pin 7 Not Grounded at Diagnostic Monitor
34 Driver Side Air Bag/Safing Sensor Circuit - Low Resistance or Shorted
35 Low Resistance Across Pins 8 and 9 at Diagnostic Monitor
41 Crash Sensor Circuit - High Resistance or Open
44 RH Crash Sensor - Not Mounted to Vehicle Properly
45 Center Radiator Crash Sensor - Not Mounted to Vehicle Properly
46 LH Crash Sensor - Not Mounted to Vehicle Properly
51 Diagnostic Monitor Internal Thermal Fuse - Blown and Short to Ground No Longer Exists
52 Backup Power Supply - Voltage boost Fault
53 Internal Diagnostic Monitor Fault
Old 10-16-2004, 07:09 PM
FordTuff1's Avatar
FordTuff1
Do I have to goto dealer to get the problem fixed or is there a way i can do it myself!!!Thanks alot Franklin2 for the code list big help so if i goto dealer i dont get jerked around,i will go like i know what i am talking about!!!LOL LOL LOL!!!
Pequeaford
01-28-2014 09:11 PM
shark1979
1983 - 2012 Ranger & B-Series
10-08-2010 08:33 PM
pablocruz69
1997-2006 Expedition & Navigator
04-24-2007 07:21 PM
mrcdsmith
05-12-2004 01:07 PM
BHOFFMAN
1978 - 1996 Big Bronco
01-27-2004 02:23 PM
Quick Reply: Air Bag!!
