Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > Flathead V8 and Flathead 6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-11-2004, 03:50 PM
StevenK StevenK is offline
StevenK is starting off with a positive reputation.
Tired of walking cause the truck quits
My 52 F2 w/239 has developed (?) a problem with cutting out and quiting. Yesterday I only got a few miles when it quit on me. I pulled the air cleaner, pumped the heck out of the gas pedal, and couldn’t smell any gas at the carb, even though the sediment bowl was full and clean. A good sam stopped, and we trickled a little gas in the carb, and it took right off.
The guy I got it from said he cleaned the tank (new seat bolts etc, so it looks like he did), installed a new fuel pump, and rebuilt the carb. There was no filter when I got it, so I cleaned the bowl and added an inline filter before this last (short) drive.
The day was cool, and the operating temp was just fine.
Could this be vapor lock ? If so, how do I fix it ?
  #2 (permalink)
Old 10-12-2004, 02:21 PM
Lazy Hog Farmer Lazy Hog Farmer is offline
Lazy Hog Farmer is starting off with a positive reputation.
vapor lock?
I solved all of my fuel problems with an electric fuel pump. I got my pump, regulator and pressure gauge ( low pressure- 2psi ) from Speedway . That was many happy miles ago. Lazy
  #3 (permalink)
Old 11-18-2005, 09:49 PM
mgraveman mgraveman is offline
mgraveman is starting off with a positive reputation.
The coil can be the problem a lot of tims when this happens. Dit it take you a while to get gas? When you let it cool, it'll run again until that coil gets hot. It's a common failure mode
__________________
2006 GMC CC Dually - Duramax/Allison
1994 F350 Reg Cab Dually PSD/ZF5 2wd
1996 Town Car
  #4 (permalink)
Old 11-24-2005, 10:38 PM
rswhitmore rswhitmore is offline
rswhitmore is starting off with a positive reputation.
The condenser could also be shorting out when the engine warms up. A tune-up is relatively cheap, and worth a try.
  #5 (permalink)
Old 06-28-2009, 08:39 AM
'49 F3's Avatar
'49 F3 '49 F3 is offline
'49 F3 is starting off with a positive reputation.
I'm having the same problem, but if I pull the choke full closed quickly enough, it'll run another 3 to 4 seconds, enough to get off the road. After it cools, I can go another 2 or 3 miles until it warms up again, then same problem re-occurs. Does the 10% ethanol in our fuel now boil in hot weather after hot coolant runs through the intake manifold? Any responses would be greatly appreciated.
  #6 (permalink)
Old 06-28-2009, 08:56 AM
junkyardjeff junkyardjeff is offline
junkyardjeff is starting off with a positive reputation.
If it still has the original flexable hose that hooks the fuel pump to the line replace it as they can collapse on the inside,the gas we have now will most likely destroy a old hose.
  #7 (permalink)
Old 06-28-2009, 09:28 PM
'49 F3's Avatar
Thank you. Hose is new, so is fuel pump. Took off air horn immediately after safely getting off the road and fuel bowl was filled to specification, float and needle valve were not stuck. (I've learned to carry tools and spare parts; ie coil, points, condensor, gaskets, blah, blah.) I've had coils in the past fail when they got warm, but a cool brand new one made no difference under warm block condition. It's got the old Ford dual carberettor rebuilt, and I didn't see any cracks or other damage. This one has me stumped.
  #8 (permalink)
Old 07-01-2009, 04:12 AM
55 f350's Avatar
55 f350 55 f350 is offline
1953 Ford F-100
55 f350 is starting off with a positive reputation.
also check your coil !!!!!!!!!! if it's bad you'll start her up drive for a bit and once she gets heat soaked your pushing 3600 pounds instead of driving it !!!!!!!i'd be willing to bet you a dollar it or the aforementioned condenser , is your problem . especially since everything else is cool . oh and don't ask how i know about the coil ....................
__________________
thats because were all opinionated bullcrap artists looking for somewhere to espout our views and show the world how much we { dont } know especially to newcomers. were on a mission to impress you and make you beleive we are all knowing !
  #9 (permalink)
Old 07-05-2009, 03:01 PM
petey shoes petey shoes is offline
petey shoes is starting off with a positive reputation.
if the above does'nt work--(i think it will)-- try checking fuel line from tank to pump. it could have some junk plugging it up from cleaning tank. might be letting SOME fuel through, but not for long. good luck
__________________
42 1.5 ton marmon herrington all wheel drive
  #10 (permalink)
Old 07-07-2009, 07:47 PM
'49 F3's Avatar
Thank you, all. I tried everything you all suggested, and the problem is (drum roll please ) vapor lock in the fuel pump! Put ice on it and runs until the ice melts, then 3 to 4 miles later, shutdown until it cools again. Was that a 6 Volt pump, Lazy? I'll get on Speedway's site and find out. Thank you, everyone, for all the help. I never would'a thunk about half of your suggestions.
  #11 (permalink)
Old 07-19-2009, 02:34 PM
Jonas1022's Avatar
Jonas1022 Jonas1022 is offline
Jonas1022 is starting off with a positive reputation.
Kinda makes you wonder what they did in the old days...
__________________
1994 Ford F-150 XL
2000 Escort ZX2 Sport (deceased)
2001 Mustang Bullitt GT
2002 Chrysler PT Cruiser
2008 Mazda Tribute iSport
  #12 (permalink)
Old 07-25-2009, 01:42 PM
Snowking's Avatar
Snowking Snowking is offline
Hail to the king baby
Snowking has a good reputation on FTE. Snowking has a good reputation on FTE.
Or atleast it was a reason why there werent fat people back then.....
__________________
2001 Ford F250/ V10 4x4 1969 Ford F100/ 300
1967 Ford F100/ 352 4spd 1957 Ford F250/ 292
1952 Ford F1/flathead 1950 Mercury M135
1949 Mercury M47 1947 Mercury half ton
  #13 (permalink)
Old 07-27-2009, 07:23 AM
kotzy kotzy is offline
kotzy is starting off with a positive reputation.
Years ago a cure for vapor lock was to put a clothes pin or two on the gas line. Sounds crazy but I have heard it worked. I'm old enough I could have done it but I never had the problem. My 39 just ran, it could over heat when pushed, should have slowed the water pumps down.
Back to your problems, have you replaced or checked the lenght of your fuel pump push rod? Could have some bearing on the problem. Finally you can do what GM did on their 350 engined trucks. The fuel lines got hot back in the bell housing area (auto transmission) so they put a return line from the pump back to the tank. Line was restricted at the pump connection. This would solve the probem but it would require a small amount of work to find or make a restricted fitting for the return line. kotzy
  #14 (permalink)
Old 07-27-2009, 09:02 AM
Jonas1022's Avatar
I thought the return line was for an emission issue with fuel vapor coming out of the tank. That was the 1973 trucks, IIRC as I had one. No vent gas cap and a charcoal canister under the hood to capture the vapor.
__________________
1994 Ford F-150 XL
  #15 (permalink)
Old 07-27-2009, 07:36 PM
I might add Chrysler did the same kind of a deal on the Omni/Horizon. No that line had nothing to do with the evaporative emissions, simply there for vapor lock/ drivability problems. kotzy
Tags
1950 , 1969 , air , cleaner , clothes , coil , f100 , failures , ford , fuel , line , lock , mercury , pin , quits , truck , vapor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
