Y-Block Identification
Sixoh has given you good info. The Y block family, 239, 272, 292, 312 use pretty much the same block, the exception being dearborn and cleveland 272 blocks. The EBV manifold will fit on later engines just fine. Look above the oil filter and also at the rear of the block on top between the heads, yo may see some stampings there.
Good luck
Bubba
Good luck
Bubba
Jag Red 54
10-24-2012 02:40 PM
