star wheel direction passenger rear brakes
I have a 93 aerostar and I can not find a good known picture of the passenger rear brakes assembly. I need to find out if the star wheel and cable goes on in the opposite direction of the drivers side. I keep having an issue with the passenger rear brake locking up when I even tap on the brakes. Any help or photos world be greatly appreciated.
on
The star wheel adjusters are stamped with a R and a L, right or left, makesure no one switched them around or replace the right with a left. The adjusting pivot nuts can be I.D. by the number of lines around around the body of the nut, one line left side, 2 lines right hand side. the lever and cable should always be on the rear shoe. with the threaded end facing the front shoe. the only thing that cause problems if some put the wrong star wheel in or swapped sides.
LostAngel
03-15-2016 08:32 PM
johnson2007
26
09-24-2011 01:25 AM
MustangGT221
11-19-2005 09:34 AM
fastg60
08-13-2004 09:33 PM
