The wife is going to kill me
(brief history) We have a 03 EB with a sunroof and the vibrations from the wind deflector drive us nuts. I was searching for a way to stop it, when I saw where someone uses a little sponge ball to wedge under it. Problem solved, sponge ball stopped the vibrations and doesn't hurt the deflector.
On to the problem. I got to drive the Expy to work this morning and, as always, I had the sunroof open. I'm sitting at a red light and start to close the sunroof. (It's amazing how fast your reflexes can work in the morning when you here that "pop pop" sound.) Well what-do-you-know, I forgot to take the ball out before closing the sunroof. Crap. I pull into my parking spot and check out the damage. The wind deflector is broken on the driver's side.
Does anyone know how much a wind deflector is and if it is any trouble to replace? I'd like to know how much it is going to cost to fix it before I tell her that we can't use the sunroof.
daveplot, thanks for the part number, but I can't get it to work for me. I went to fordpartsnetwork.com and fordpartsmall.com and neither one recognize that part number.
At lunch today, I went to the Ford dealership closest to work and the parts guy couldn't find it in his computer. I'm going to try taking the Expy with me tomorrow or Friday (if the wife will let me touch it again) and show it to him. I didn't have the part number you gave me when I went in, but I'll take it when I go back.
This is getting to be a lot of trouble for one little part....
See if this link works:
http://www.parts.com/partlocator/ind...03&catalogid=2
If it doesn't I chose the collision catalog then roof, sunroof, air deflector.
Originally Posted by daveplot
When I searched at fordpartsnetwork.com with the part number it works.
Good question, you made me think of something...Will it hurt anything if I just remove the deflector all together? Does it serve any other purpose, or is it just there to deflect the wind?
It sounds like the headliner is acting like a large woofer, transmitting very low frequency sound through out the cabin.
YIKES!
I've really screwed up now...
Last night I took the deflector off. Two little screws, fold it over, and it comes right off. But upon closing the sunroof, I forgot about the two little pieces that spring up to push the deflector up. Now, the sunroof won't open. It will still vent, and it tries to open. It'll move back about an inch then stop.
Anyone know where I can get a factory service manual to take the sunroof apart?
I'd take it to the dealer and let warranty cover it, but I think it is a little too obvious that it was my fault. Maybe I need to take it anyway, my luck is getting worse.
By the way, the diagram I got from fordpartsnetwork.com shows the deflector (although, it is not an accurate drawing and I still don't know which part to order), but the diagram the parts guy at the dealership gave me does not show it. Go figure.
