'98 4.6L still pinging
It did help. I'm not getting the ping as frequently. My next step is to take it to Jiffy Lube and have them do the injector cleaning system. I read on this forum that it fixed the last 10% of the pinging problem after the pcm was reprogrammed. I'll let you know what happens after that. I think the reprogramming fixed about 90% of the problem. Let me know how yours turns out.
NP
NP
any ping is to much
So can you tell me what they did exacly to your 5.4 to make it stop pinging. i called the dilership and they never heard of it. If there is any more info you can give me so i can git mine to stop pinging i will try to replace the egr flow sencer. and cheak again for vac leaks. thanks
the reprogramming did work some, but I still had the ping. This week I put 89 octane gas in instead of the 87 I usually run and all is well. Absolutely no ping. I'm not sure how to make it run correctly on the 87 anymore, but I'm wiling to pay the extra 10cents a gallon for the 89 as long as I don't have to put up with the alternative.
78_79ford
09-07-2015 05:48 PM
CoachmenCaperXl
43
10-30-2011 02:36 PM
Milwaukee1979F150
10-04-2010 12:17 PM
