Door Lock Actuator Replacement Procedure (Enhanced)
#65
Maybe the actuator replacement will work on my problem but I thought I'd run it by all the exerts before I commit.
When I turn off the truck, the locks function properly if I use the button. They all lock and unlock. My problem is, that when I turn it off, locked or unlocked, doors open or closed, the locks go up and down like maybe 8 times. Then theres about a 15 second break, then they do it again. It keeps doing this endlessly. Not always 8 times though, sometimes it's only 3 or 5 or 2 or 1. Totally random. I've pulled the fuse for the locks. There's a clicking under the dash that's causing the locks to go crazy. If I put the fuse back while under the dash is clicking, the locks start to move. Any thoughts please????
Thanks
#66
Stewart
MuddyAxles
01-26-2018 03:23 PM
Liam Dean
06-01-2016 11:31 AM
