Hiccups
Hiccups
I just bought a 95' F-250 7.3 auto. The engine runs great except for when it hiccups. The whole truck will start to jerk and the rpm gauge fluxuates up by a few hundred then it will stop. It does it any time at any rpm. I have had the codes read but it did not show any. Sometimes the check engine light will come on but most of the time it won't. I have changed the oil, and every filter on the truck. Air, fuel, everything. It is driving me nuts! Please help!
John
were is this connection????
On my 97 I do not have any wires on my fuel bowl(drivers side) i do have
a rectangular box connected to it and then a wire connecting to that..
I have wires in the front of the fuel bowl down low..
Do you have a picture??
Your the second person to tell me to try this, but i cant find it
and the Ford CD is worthless for pictures
My brothers truck (175,000, 95 .psd .auto) does something similar to this only when engine is cold. I wouldnt really call it a hiccup, more like a pulsating of the engine or erratic type running condition. It only does this with minimal load on it and straightens out when you accelerate, and runs perfectly after engine reaches normal operating temperature. Is this what you guys are describing? If not has anyone else ever experienced this? The PCM and the CMP have been replaced for other problems as well as fuel filter and mechancial low pressure pump. Will be testing and replacing all injectors soon, just wondering if we are headed in the right direction as the injectors are original. Thanks-Ryan
Pictures and story: https://www.ford-trucks.com/forums/s...d.php?t=278697
Thanks Kwik. Appreciate the help. This truck burnt up a wiring harness last year in the pass. side valve cover so its new and the problem never got better or worse. Will be replacing glowplugs when we do the injectors so I'll definitely be sure to check out the other side. By the way the truck is not actually missing, its hard to explain. Its almost like he is feathering the throttle only really fast, faster than the human foot can move. I know what a miss is like and this is different. With a strait pipe I can really hear what the engine is doing throught the exhaust. Since this truck only does it when its cold (which is at least 5min every time he drives it) I would think we would get a DTC for a missfire or something, actually I am hoping for one, but after 3 years of this I dont guess we'll be that lucky. Thanks for your help!
Ryan
Ryan
