Well i have a 87 Bronco 11 i am what into put a 4.0 in. do any one know if that a 4.0 will bolt up to a 2.9 manual it's a mitsubishi type. and do i have to take the 4.0 computer???
The 2.9 tranny WILL bolt up, but it is not recomended b/c the tranny was not made to hold that kinda of torque. I will hold for a little while till you can find a 4.0 tranny, but you'd better find one ASAP or you will have 4.0 swap, sitting in the garage b/c the tranny is shot!
Just got an '86 BII from my grandfather. So far no complaints, but I can't leave well enough alone and was considering a 4.0 swap. I found a '95 Explorer on craigslist for a donor, but I believe the tranny is a 4R55E. According to some information I found online, the A4LD and the 4R55E are essentially the same. Can they be interchanged? I ask because it would be easy to swap both the engine and tranny at the same time. Are they the same length? Any help would be appreciated, thanks.
