Body Parts Interchange 1952 and 1950
I am contiplating doing the same with my '51 F-4. As far as I know the front end will bolt right up. Although I have seen it done, I don't think the hoods from the different years will bolt in directly without some modification. The hood latch system is completely different. As long as you keep the same year hood with the corresponding front end there shouldn't be a problem.
If I go with the swap, which will not be even started until next year, I am also going to swap dashboards. The only thing that will tell that it is a '51 is the larger rear window, which I think will be better with the flatbed and full side racks.
19fifty4
02-26-2012 02:50 PM
91Bear
03-31-2005 06:12 PM
Franklin2
10-31-2001 11:57 AM
