looking for a stronger engine cradle...
Stress cracks
Since the 1983 F-150 did not come from the factory with a 460 I must assume that somebody else put it there. If the reference you make to cradle is the steel engine mounts connected to the frame, they are likely the wrong ones if they are cracked. You need the steel frame mounts for a 460 engine which only came from the factory in the F-250 and F-350 models. You need to visit a salvage yard or eBay and get the correct steel frame mounts. The isolators, or rubber mounts are available at any big chain auto parts store.
nobes1969
19
09-28-2017 07:31 PM
Santiagoeford
01-07-2017 04:49 PM
irhunter
19
07-29-2015 09:30 AM
