Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-07-2004, 02:43 PM
Norick54f2 Norick54f2 is offline
Garage is empty, add now
Norick54f2 is starting off with a positive reputation.
identification of a flatty
hi, i jsut got a flathead ford out of an old old shack and the guy knows absolutly nothing about it, so i tore it all apart , it did turn over , it has been rebuilt to .030 over , clevitte 77 bearings all around , gaskets looked newer , but im going to redo it all again , it has been ran on the rebuild. i was wondewring if there was a stamp of the year or anything on the block. it is made in the US, single carb, 3 studs hold carb on , 24 bolt heads.There is a bunch of stamps on the intake flat on the block , not sure what they are all for , i just want to know waht year it is so i can order rebuild stuff , thanks
  #2 (permalink)
Old 09-07-2004, 05:03 PM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.
The place to start
www.vanpeltsales.com/FH_web/flathead_home.htm
The numbers stamped on the rear outer intake surface on the passengers side COULD be the Birthdate of your flatty.
Did you measure the stroke? that will count
__________________
Dick C
Erie, PA
1948 Ford F1 Panel
1952 Ford F2 (Non-Stock Flat 6)
1997 Ford Explorer
Every Thing I've Ever Said Is A Lie
  #3 (permalink)
Old 09-09-2004, 09:29 AM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Here's the link for dating last series flatheads:
http://flatheaddrag.com/birthday.html
Dick gave you a great link where you will find what you're looking for.
For a quick tip, head description helps - do the water outlets come out the middle of the head? If so, look at the bell housing area and see if you find a "59" cast on the bell. While you're there is there a half-bellhousing cast as part of the block? This is the middle series and you want to order parts for a "59" or "59A" or "59AB" or any other series of letters. These were cast from 1945 thru 1948 for cars.
If the water outlets are on the front of the head and have a thermostat housing the bolts to the head, it's the late series and is known as the 8BA used 1948 thru 53 (and '54 in Canada) It has a no bell housing cast on the rear of the block (like modern engines)
1948 is the crazy year and easy to mix up. Cars used the model 59 that year, but trucks rec'd the 8RT(same as the 8BA). Confused yet?
  #4 (permalink)
Old 09-12-2004, 12:08 AM
hey guys , this is helping me out alot thank you much . haha well not really confused , i have somewhat of an idea of what it is but not to the dot yet , the water outlets are on the front with the thermostat housing so its in the 48-53 range but it does have a casting on the rear of the block by where the bell housing bolts up i cant read much of it though , ill try and get it but thank you alot guys
  #5 (permalink)
Old 10-10-2004, 04:19 PM
mantta's Avatar
mantta mantta is offline
mantta is gaining momentum as a positive member of FTE.
It sounds like you have an 8BA engine. That number is cast on the cylinder heads. It is a 49-53 if it is an 8BA. It is rated at 100 HP.
__________________
ENCS(SS), (SW), USN RET (E-8)
Keweenaw Bay, MI
U.S. Navy (Submarine Service) 60-80
2010 Ford F-150 4WD Lariat Ext Cab
1999 Lincoln Town Car Ecec Series
1930 Model "A" Coupe
Tags
1948, 59ab, 8ba, dating, engine, flat, flathead, ford, fords, head, id, identification, motors, sale, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
