TPS replacement question?
Hi, am going to replace the Throttle Position Sensor on a 89 f250 302 fi, was wondering if this can be removed and replaced without having to remove the throttle body . Also is this sensor just a remove and replaced item or are adjustments, or alignment of this sensor required.
Any info is appreciated.
replaced tps now idle too high
EPNCSU2006
Replaced tps and check voltage, voltage was .92, now idle speed is too high. Have readjusted timing twice but it does not make any difference. Idle speed is around 1500rpm, have also replaced Idle speed by pass valve, ?Know I did something wrong but do not know what it was.?
Any info on where I should look for problem would be apprieciated!
Did you put a new gasket on between the throttle body and the intake manifold? It sounds like there is a vacuum leak somewhere. Also might want to try resetting the computer by disconnecting the battery for 10 minutes or so if you haven't done so already. It should work fine, so long as you didn't mess with the throttle stop screw to get voltage to the right place.
gasket vaccumn leak
EPNCSU2006
You where right,. there is a vaccumn leak on gasket.
Replaced the gasket twice aready. I lightly oiled it before installing, Is that the correct thing to do or should it be installed dry.
I did clean mounting surface area with throttle cleaner and used a popsickle stick to remove any gasket material that where stuck to mounting surfaces, so I believe surfaces where clean and undamaged. Have one gasket left, will check throttle mounting bolts again for torque specs. Then try to seal leak with new gasket. If I am doing anything incorrectly please let me know what it is.
Appreciate your responses! Thanks
makuloco2000
02-27-2014 10:26 PM
jsimpson
01-18-2009 07:35 PM
runner
13
10-06-2006 04:15 PM
