Tightening belts
Old 09-06-2004, 03:40 PM
Elemenopy's Avatar
Elemenopy
Elemenopy is offline
Arrow Tightening belts
Ok I was planning on converting my '51 F-3 to 12 volt but I decided I'm going to wait untill i have all the parts needed. Instead of having a grounded truck for a little while. But I took the generator off and every thing but I cant get the belts tight again. Any help on this I would love! Thanks again.
Elemenopy.
Old 09-09-2004, 09:36 AM
mtflat's Avatar
mtflat
mtflat is offline
Here's what I do. Place a 2x4 across the fenders above the generator. Get the generator about where you want it with friction from the nut holding it in place. Use a light duty chain or rope to loop under the generator, bring it up over the 2x4 and bolt/tie it on top. Then a pry bar on the 2x4 under the chain/rope will gently bring it the rest of the way up to where you want it.
Remember you don't want it tight - keep 1" belt deflection on the longest run of the belt. Too tight and you'll destroy bearings in waterpumps and generator.
Old 09-09-2004, 02:27 PM
Elemenopy's Avatar
Elemenopy
alright I'll try that out!
Thanks again!
Elemenopy
CoreLokt
03-14-2016 06:13 PM
norvillebob
64
02-07-2016 11:45 AM
SVTDriver97
13
09-21-2014 08:06 AM
B_line66
08-22-2014 07:13 AM
WalterRoad
08-01-2014 04:45 PM
Quick Reply: Tightening belts
