supercharger interchange
Old 09-01-2004, 12:59 PM
bladesxxx's Avatar
bladesxxx
bladesxxx is offline
Help, I have a 1997 F150 4.6 and I have an opertunity to purchase a supercharger from a 5.0. Can someone tell me if this fit my 4.6
Old 09-01-2004, 05:44 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
It'll probably work with the proper bracketry and ductwork. A roots/twinscrew will require a different intake manifold, and inlet, a centrif will require a different mounting bracket and ductwork. Both types (roots or centrif) will require different pulley combos
Old 09-01-2004, 07:50 PM
bladesxxx's Avatar
bladesxxx
Supercharger
Sounds like it could get expensive making the conversion. I will need to check cost out. I am just wanting an extra boost in the mud for my 4x4 with the 34.-16-12.50 tires. Any other ideas on this.
Thanks
Old 09-01-2004, 11:22 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
It is never cheap when you are dealing with power adders.
Old 09-02-2004, 04:24 PM
2000BLK54's Avatar
2000BLK54
2000BLK54 is offline
Yup....even if you got the brackets, pulleys, and a proper sized belt there is a lot of peripherals that need to be addressed. Fuel system upgrades (pump, injectors, FMU...), monitoring gauges (boost, fuel pressure, A/F ratio), and finally a custom tune to bring it all together. Then you'll need to beef up the transmisson to handle the extra power. $$$
Marcus0418
2004 - 2008 F150
05-19-2015 05:58 PM
josh84
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
09-16-2007 04:33 PM
mthompson
Modular V8 (4.6L, 5.4L)
05-05-2007 10:50 PM
fordmarshall111
2004 - 2008 F150
09-11-2005 08:07 PM
Quick Reply: supercharger interchange
