Thickness of front discs?
Old 08-26-2004, 04:52 PM
thesprocket26's Avatar
thesprocket26
thesprocket26 is offline
Concerning 73-79 f100's, what are the numbers of how thick your front disc brake rotors should be? How thick is brand new and how thick is serviceable? Thanks ya'll!
Old 08-26-2004, 06:32 PM
jrsroadhauze's Avatar
jrsroadhauze
jrsroadhauze is offline
28.46mm or 1.12" is the minimum
Old 08-27-2004, 09:29 AM
beartracks's Avatar
beartracks
beartracks is offline
It's almost allways cast into the disc somewhere. It may be hard to find but it's possible aftermarket units might have a different minimum.
Old 09-01-2004, 08:38 PM
wckdclwn911's Avatar
wckdclwn911
wckdclwn911 is offline
or you can say 2/32nds, or roughly the distance from the top of a penny, to lincolns hair
Old 09-01-2004, 09:31 PM
thesprocket26
wickd 2/32 is 1/16. And that isn't very thick. What are you talking about?
Old 09-01-2004, 09:52 PM
wckdclwn911
Im talking about the actual thickness of the pad, not including the metal plate that backs the pad. I know that 2/32nds is also 1/16, but at the garages Ive worked at we measured everything in 32nds. It is the same as your tire tread depth, which in VA, if its below 2/32nds, it not inspectable. Some brake pads will have rivets in them, which can also be used to judge when you need to replace them.
Old 09-01-2004, 09:54 PM
wckdclwn911
Never mind, I see you said rotors, not pads. Guess Im reading to fast and the Old Mill aint helping. I cant remember the rotor width, but if you havent found out by tommorrow, Ill let you know
Old 09-02-2004, 02:06 PM
thesprocket26
Hey thanks man. That info is good to know too. I was confused about what we were discussing. Rock on!
Old 09-02-2004, 02:25 PM
ranger429's Avatar
ranger429
ranger429 is offline
I think all the aftermarket brake rotor's are set at the same minimum thickness as to what is original equipment spec's. Usually on the inside of the rotor on the hub by the fin's is where they cast the minimum thickness.
Originally Posted by wckdclwn911
or you can say 2/32nds, or roughly the distance from the top of a penny, to lincolns hair , Im talking about the actual thickness of the pad,
Where do you buy your brake pad's? Take a look at a penny and tell me that is how thick your pad material is. The actual pad is more like a 1/4" of actual pad thickness. The rivet head itself is about 2/32".
I do not think they are even bonding pad's to the metal plate any more unless you got a lightweight JAP car or something, there were to many problem's with the bonding breaking loose.
Old 09-02-2004, 11:00 PM
CrazyAirman's Avatar
CrazyAirman
CrazyAirman is offline
Hmmm..... not true... in fact MOST OE and aftermarket pads are now bonded, as its the riveted ones that will heat crack and come loose from the backing plate.
Old 09-02-2004, 11:07 PM
andym's Avatar
andym
andym is offline
Most quality pads are bonded. In fact, you want to stay away from the riveted pads, because if you let them grind at all, you *will* be buying a new rotor.
I saw a rotor once where the customer let a riveted pad grind for about a week. the braking surface was completely gone. Worn all the way down to the rotor vents. I had to look at it for a few minutes to recognize it as a rotor.
Old 09-02-2004, 11:23 PM
CrazyAirman
I had one come in yesterday, on a fullsize Bronco, was ground so bad that the "rotor" portion had literally separated from the hub portion, it was just crashing around in their, and they lady drove it away, because I wouldnt just put pads only in.........
Old 09-03-2004, 05:25 PM
ranger429's Avatar
ranger429
CrazyAirman, I sold a lot of part's back in the 80's and all I saw returned was the bonded pad's coming back on account of seperation. Maybe they have changed there "gluing" method. I still do quite a few brake job's and I have yet to see a set of bonded pad's come over the counter from the part's man for a chebby or a FORD, in fact my sister just brought over a set for her grand am that I have to change, they are riveted as well. With 6 or 8 rivet's in a brake pad they can heat crack but the chance's of the broken pad falling out are quite slim as the rivet's will still hold it in place somewhat.
