How much carb (cfm) @ 7000 ft?
Having 390 built with 9 1/2- 1 compression, comp 270h cam, edel heads, rpm intake, stans' headers, msd....and i want to put a speed demon carb on, but I don't know if a 650 would be enough for my altitude or if I should go with 750. I have read on here that demon's flow a little better than advertised. Any suggestions?
I'm surprised no one has replied.
I'm not making any recomendations, but I've never heard of altitude being a factor in sizing a carb. Equipment, set up, and intended use pretty much dictate how much carb is enough.
Altitude becomes a factor when you start tuning. Things like ignition timing and fuel metering unlock the potential you spent big bucks on.
Scouder, are you out there?
Sorry amigos, but altitude makes a huge difference in every facet of building/tuning an engine. Incuding carb size.
I also live at 7000', and the amount of available air here is reduced about 23% from sea level. Which means that any normally aspirated internal combustion engine will have a 23% reduction in volumetric efficiency. Which is another way of saying your engine size is effectively reduced by that value. A 390, for example, becomes a 300 at 7000'. Whatever carb you would run at sea level you can knock 20% right off the top at this altitude. A vehicle that requires a 750 at sea level will run just fine here on 600cfm. Compensating for altitude with a smaller carb increases fuel charge velocity and helps with low end response.
Hope this helps.
-Scouder
Hope this helps.
-Scouder
Hey, that's cool that your just over the hill. We just finished rewiring the computer network for the school district over there.
I ran your engine through a spreadsheet that I wrote. Even being extremely generous with the volumetric efficiency (80%) I show a 650 being more than enough at this altitude. If you were running at sea level (assuming 95% VE) it would require a 750 if you wanted to spin it over 6000. You won't kill yourself either way, but there is no sense over carbing if you aren't going to hot rod it at sea level very often.
-Scouder
-Scouder
11-24-2012 10:23 PM
DJdemon6696
13
01-28-2010 09:36 PM
ford truck oldboy460
02-23-2009 01:32 PM
proeliator
10-03-2003 07:01 PM
